Random stuff
jdpolzin
Needing a few random things.
1. plastic block that goes between the lower spoiler and the core support. I have one side but need the other.
2. Wire from the fuse block to the trunk that goes to that pops the trunk open. This is in a black plastic conduit.
3. E-Brake cables from the E-Brake pedal all the way back.
4. Shifter cable
5. Upper plenum 86-87
6. New Visor sticker (repro)
7. Yellow sticker for radiator cover (CAUTION HOT)
8. Serpentine sticker for core support
I should have the conduit laying around all you would need is some black 16gauge wire from the part store. The conduit goes from the lock in the trunk to about where the rear seats are then its black wire all the way til the glove box switch. I got a fan sticker too.
Yeah I want the factory ends on it. I actually have the conduit here but the end was cut off. I could splice it but would rather not.
I have 2 and 3, might have #1 if you can send me a pic.
Here's a pic of the side I have, I need the opposite side. This piece attaches to the lower spoiler that has the cutout for the intercooler.
How much are you looking for the fan sticker Stefan?
Looks like I have the black wire there or the Power Trunk release. But I need the actual trunk latch with the POwer Release on it. The wires that are cut are the orange and blue.
OK thanks to the help of you guys, I have definately located numbers 1,2,5,6,and 7 so far! Thanks a lot guys!
I have an original GM Accessory Belt Routing sticker. I'm not sure if it is correct. I bought it from Fennessey Buick back in 1995. I can send you a picture if you give me your email address. Also, the part number on my sticker is 25523397. Perhaps you can match it up to yours if possible. My email is mchughn@netscape.net.
