Random Tech. Cat. Conv.
salvageV6
Daily Driver
Anyone know the overall length of the RandomTechnology cat. # 923007?
That is the one for 3" downpipes.
I emailed them but they say there may be a delay in answering.
Any comments about that cat. would be appreciated. :)
TIA
I just hollowed out my cheap one. ;)
Want to try a good one to see if I can leave it on the car even after I pass emissions.
Gained 5 psi. boost with the hollow one. :eek:
Anyone???...... :confused:
I have the latest BGC 3" version of the 923007 Random Tech cat and it's 15-3/4" long end to end. That may be meaningless to you because anyone can spec their own lengths.
I had the same cat from 1996 which started to break up internally last year, I'm told due to water getting on the shell when it was hot. I don't think I picked up more than 1-2 psi boost after I helped it break down the rest of the way ;)
Anyway, the later version seems to solve this problem with a sheet of something wrapped around the honeycomb to isolate it from the shell.
Hope that's the info you needed.
Mike [:-)
Yes that is very good information. :)
A bit long but should fit in my car with the THDP.
I'm leaning toward leaving the hollow one on there now. :D
23psi. on alky. is addicting.
