For my engine building experts out there:
Time to start piecing together my orginal numbers matching block. I removed and totally dis-assembled it back about 1991 and at the time it had about 120,000 miles on it, some racing but nothing real hard core. The block has been all cleaned and totally stripped.
I'm hoping to be able to re-use all the original internals with no machine work needed.
The cylinder bores still have a hint of crosshatch, and while there's bit of a stain at the top and bottom of them, there's NO ridge, none, nada. Out of round and taper are barely measurable. No more than .0001-.0002
Here's the bores
1-3.7999
2-3.8000
3-3.8000
4-3.8000
5-3.7999
6-3.7999
I hope the differences are just my eyes trying to read the cylinder gauge. If I had to say what I saw mostly, it would be closer to 3.79995
Now the pistons. I measured at the top land and at the middle skirt at the pin level
1-3.7486 top (clearence to bore .051)
1-3.7953 skirt (clearence to bore .0047)
2-3.7496 top (clearence to bore .050)
2-3.7950 skirt (clearence to bore .0050)
3-3.7491 top (clearence to bore .050)
3-3.7956 skirt (clearence to bore .0044)
4-3.7500 top (clearence to bore .050)
4-3.7950 skirt (clearence to bore .0050)
5-3.7495 top (clearence to bore .050)
5-3.7954 skirt (clearence to bore .0047)
6-3.7483 top (clearence to bore .051)
6-3.7955 skirt (clearence to bore .0044)
I'm hoping all I have to do to the cylinder bores is a quick ball hone just to clean up the stains. Correct???
Here's the original crank. Just had the journals all polished.
Main journals:
1-2.4994
2-2.4993
3-2.4992
4-2.4994
Rod journals
1-2.2486
2-2.2486
3-2.2487
4-2.2485
5-2.2486
6-2.2485
Can I assume from these measurements that I can order "standard size" bearings for the mains and rods???
I haven't het measured the rod big ends for out of round but I'm betting they'll also be OK.
My first order will have to be main, rod and cam bearings. Then I'll have to find a set of block plugs.
ADVICE welcomed!!
Here's the bores
1-3.7999
2-3.8000
3-3.8000
4-3.8000
5-3.7999
6-3.7999
Main journals:
1-2.4994
2-2.4993
3-2.4992
4-2.4994
Rod journals
1-2.2486
2-2.2486
3-2.2487
4-2.2485
5-2.2486
6-2.2485
ADVICE welcomed!!
