Rear Disc Conversion Kit By Little Shop - Opinions ( bolt on )
The kit in the original post won't work well. It doesn't tie into the wheel cylinder bolt, just the flange bolts. There's not enough meat on the axle flange to rely on just the flange bolts.
The Rite Stuff kit will work. The parking brake mechanism on those calipers is a bitch. You'll also get pad knockback because of the slop in the axles unless you put C-clip eliminators on it.
If you aren't racing the car in a way that requires the heat shedding of disc rear brakes, they're not necessary and might work worse than the drums. Just be aware.
