Rearend?
VKREGAL
what rearend is on an 84 na regal. 7.5 or 7.625. i need to get ring and pinion gears so i need to know this. Also are the ring and pinion gears the same for both cause on summit they list them together and seperate
thanks
If you're using the stock carrier it's a 7.5 but if you're changing the carrier you can change to the larger one.
7.5 and 7.625 are exactly the same carriers and Ring & Pinions. GM must have figured out they weren't using the correct way to measure the ring gear some time around 1985. Really that's only a 1/8" of an inch. Not much of a difference that's worth bragging about anyway.:cool:
Thanks Eric. I didn't know that. What gears are you looking for? I've got a set of 3.42 waiting to come out of a camaro rear end at the housing if you are interested.
Sorry to hear that. All this needs is new pinion bearings and the carrier would've been ready to install. I put new bearing on the carrier for a customer and it was never picked up so I'm keeping the disc brake set up for myself. Just haven't gotten around to taking it apart yet.
The Specialist returns...:biggrin:
Stay well Eric....you're sorely missed.
