Aug 6, 2011 #1 D dognut New Member Joined Feb 20, 2011 Messages 31 Got some blue smoke coming out of the exhaust pipe.I beleve the oils coming from the turbo exhaust side.What rebuild kit or seals do I need. Not long ago I checked the wheel play & there wasn't much.
Aug 6, 2011 #2 J joey316g Too many cars. Joined Dec 14, 2010 Messages 252 This place has a couple kits. G-Pop Shop :: Rebuilt Kits quick links :: Garrett T3, T4, T3/T4 Rebuild Kits
Aug 6, 2011 #3 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 First off, pull the down pipe off and see if there's oil in it. It could be as simple as the PCV system putting oil in the engine. Very common.
Aug 7, 2011 #4 T TRYMYSIX Member Joined Jun 30, 2011 Messages 459 charlief1 said: First off, pull the down pipe off and see if there's oil in it. It could be as simple as the PCV system putting oil in the engine. Very common. Click to expand... If there is oil in the downpipe is that a bad PCV? Just put a new one in mine and still have oil in the downpipe....
Aug 7, 2011 #5 C charlief1 RIP Charlie! Joined Sep 20, 2007 Messages 23,936 TRYMYSIX said: If there is oil in the downpipe is that a bad PCV? Just put a new one in mine and still have oil in the downpipe.... Click to expand... Not my meaning. If it's in the downpipe then it's either the engine or the turbo. If it's just smoking it could be the PCV system.
