I am rebuilding my motor this week and will have it done by the weekend should i get some head work done or leaveit stock for now. If i am going to lose a lot of power by using the stock heads with the set up that i have then i can do some work to them before going back in.If so what should i do to them, will a good port job get some more power out of it.this is my set up let my know if you think it will help me out with some more power.
307 pump[hot wired]
adj reg
40lb injectors
ta 33 turbo
sperco intercooler
atr up pipe
atr down pipe
LT1valve springs
comp cams 206 cam, lifters, timing set
87 ecm
JOE L 93and 110 chips
ram air kit
30 over pistons
stock heads, and intake
help need to go 12s
307 pump[hot wired]
adj reg
40lb injectors
ta 33 turbo
sperco intercooler
atr up pipe
atr down pipe
LT1valve springs
87 ecm
ram air kit
30 over pistons
help need to go 12s
