HI,I have a red armstrong TWIN PUMP system with his hot wire system and hobbs switch for the second pump......MY PROBLEM is the fuel pump relay in his system has become defective 3 times ...the relay will usually last about 100 miles and then i have a no start condition....plug in another relay and it will start up this is on the primary pump ,i have no problem with the second pump side or hobb switch...help also no fuses blow.
