- Aug 1, 2003
reds double pumper setup complete
very low use and only on c16
the hanger/sender is reds with twin xp's and heavy gauge feed wire
this setup has an upgraded ATR dbl pump hotwire harness for the engine bay which has hotwire (relay) for second pump and adjustable hobbs with mounting plate and vac line with tee.
reds feed was not hotwired and used a much cheaper non adjust hobbs switch
475 shipped USPS lower 48 , add 10 for canada
