Reflash Powerlogger?
jmendlik
Can someone post instructions or a link on how to reflash Powerlogger?
I have PLC 1.4.0 and want to flash to the PL030.s19 file
from the help tab, click the Reflash PL button, choose the PL030 file and click ok, a window should appear showing that the reflash routine has connected to the PL and ask "are you sure", hit enter to continue and reflash.
Bob
If you have a scanmaster connected to the powerlogger, when you turn the key on, it will display the PL flash version.
the help/about on the PLC software will display the PL version once you have connected/logged.
Bob
Bob-
reflashed successfull but its still not holing connection-then it stops connecting altogether and gives com port error. Can I call you and step thru driver install?
scanmaster now shows 3.0
Joe
Does it stay connected if the engine is not running?
it sounds like you need the grounding update on that unit.
send me an email and I will go over the details.
Bob
Bob-
Got the drivers to try and load and it said my drivers are up to date...so Im ok there.....I watched your video-but this is a black powerlogger I'm using. I will drive car tomorrow and see what the result is..
JM
