SignUp Now!Dave's way works I would just go a little higher than he recommends.It's not bad at all, I swapped mine out as well, I made a thread about it. Dave husek helped with recommendations on how to make it safe, Dave husek actually does his on Jack stands as well. Look for my thread in the transmission section
I had a ton of Room but the main thing I did he suggested was put rims under the rear tires so it supports the rear end and prevents it from moving.Dave's way works I would just go a little higher than he recommends.
Sent from my SGH-M919 using Tapatalk
Cool idea, never thought about doing that. Hopefully I am DONE laying under cars and trucks (for friends). 55 today. Stick a fork in me, I'm DONE!i don't use a trans jack....two ratchet straps from frame rail to frame rail...after the trans is free, lower it onto a sheet of cardboard and slide it out.
