Does any one know where to get the molded rubber hose that has clamps on it which goes from the powermaster pump to the bottom of the reservior.  Also the short brake hose (about 6 inches long with a banjo fitting on one end and a threaded female fitting on the other end) that goes from the powermaster pump to a short steel hardline that then goes into the powermaster housing that the reservior sits on.  Mine are pretty dry rotted and need to be replaced.
Thanks.
			Thanks.
