Replacement hoses for Powermaster
MSKBuick
Does any one know where to get the molded rubber hose that has clamps on it which goes from the powermaster pump to the bottom of the reservior. Also the short brake hose (about 6 inches long with a banjo fitting on one end and a threaded female fitting on the other end) that goes from the powermaster pump to a short steel hardline that then goes into the powermaster housing that the reservior sits on. Mine are pretty dry rotted and need to be replaced.
Thanks.
Call Brian at GBodyParts.
GBodyParts.com Online
I would guess what he has is used, but probably better than what you have.
The suction hose that goes from the reservior to the motor could be replaced with standard line if you could find one that would fit well enough. You wouldn't want any kinks in it.
The pressure hose must be exact.
HTH
Z
Powermaster brake hoses
I was hoping to get new ones, but I might have to buy used. Does any one know if GM still sells them, or if any one is making them for the aftermarket?
Thanks.
