results are in
87GN 98GTP
Andrew
the car runs flawless after over a year, special thanks to the bob bailey ignition system and the setup cured my problems, runs til about 6500 making 530ish(more to come when I run it with the dump open). It may seem low for my setup but its a dyno jet which numbers are typically a little lower plus I have a turbo 400 non lock tranny which doesnt show up on the dyno, the guy that tuned it all says it about a 10flat car on pump on 21 on timing and 21boost so i can def run more with pump, my converter eats up a lot on the dyno but a car with the similar setup making like 580 runs high 9s all day long, a day at the track is calling soon
Congrats! Bring that beast down to the Nats this year so you can run it all out! Hard to find a track around here that'll let you slide on the cage if you don't have one. I'm glad to hear your car is coming along though. Eric will be pumped as well.
he def is matt, i talked to him today, he was expecting higher numbers but as the guy who dynoed said it would make about 700 on a 200r4 lock up setup but the turbo 400 on dyno numbers is totally different he said, he was really surprised im up that high on this setup, he has a car ls style with turbo 70mm on a 5.3 ls block making 12lbs and cammed and he made 480whp and he ran a 10.4 with a mushy converter turbo 400 too so def made sense then
Clear case of the coulda shoulda woulda's. Take it to the track and see what it does. That will eliminate most of the BS.
What was Injector part number, dc, and, fp?. My guesstimate on a dyno jet with your number is 10.60-10.70 with a hard leaving car.
btw where are the nats? doubtful cuz im out of time off and have a 2 month old
Bowling Green, KY Oct 17th-20th this year. I have a 7 month old so I know how hard it can be. The Buick GS Nationals happen every year though, so I recommend going at least once even if you don't race. It's hairdryers and angry chainsaws all day.
And she won't like your answer for where you are taking her for your 1st anniversary
