Feeding water directly into the water jackets have my ears at attention. Do you know what the ID or OD of the plumbing feeding the water jackets is?
The powersource book shows 1.5" up to the pump, but no size given from the pump to the water jackets.
Thanks.
Sorry never answered your size question.
The freeze plug holes are 1.5" ID and the fabricated manifolds fitted into these are 1.125"ID. The intake to the manifold is just over 1" ID so the water velocity is slowed down to about 40% as it enters the block (vs pump outlet).
The return pipes are also 1.125" ID - two of them. There are two essentially separate water systems - one for each bank, including two rads - they join just before the water pump and then separate again immediately after the pump.
