I'm stumpped.
I don't know what kind of rust you guys have down there, but here, when they rust (detroit) they rust. You can "rub off" the rust with any sort of method you choose, but there's no way you're going to convince me, that after the rust's off, that it "shines" all over again... You guys must have never seen these rims when they were brand new, because there's no freakin WAY your rim shines like new, after you just removed the rust. I have a set of beater rims I use, when I'm not at the show, and they were very slightly rusted on the outer portion of the rim, and I started very gently, (brasso) and moved up, till it came off, and they are nowhere NEAR shiny. I mean nowhere NEAR. They're all dull and **** where the rust was...
You must mean surface rust. And by surface rust, you must mean, after the car sat for 3 days in the rain... and that's it. Any longer, and it's going to pit. There's no way you're shining the steel underneath where the pitting eroded the chrome off, to a sheen that was just like the factory chrome. Unless you
wet sanded it with 1000 grit paper for hours, then took a buffer wheel on an electric drill motor to it, while working down from a course rouge, all the way down to the finest they make. THEN re-clearcoating it, before it rusts all over again, within 5 minutes. Ask me how I know that...
