SignUp Now!Did you take any pics installed of the engine bay and/or under the car?I have one...after market stock style header..not fun installing. U will need to dent the floor on the pass side where the cat used to be just to get the pipe in. Also had to unbolt header and leave in the car just to get some wiggle room. Looks cool as hell ! I even made the stock turbo shield bolt up ...
seeya v6 said:This is the only pic I can find.. It does touch inner fender plastic liner...
I'm running Poston headers. Like Seeya6 said, had to beat the passenger floor pan to clear, but didn't loosen the PS header.
What size DP were you guys running before the 5"?? What type of power and sound differences did you experience? Either seat of your pants or track/dyno....I have one...after market stock style header..not fun installing. U will need to dent the floor on the pass side where the cat used to be just to get the pipe in. Also had to unbolt header and leave in the car just to get some wiggle room. Looks cool as hell ! I even made the stock turbo shield bolt up ...
	Your T is just plain sexy!!!I have the same DP with TA 4 bolt SS headers. Without the Heater box in the car, it is very easy to come in/out. Lots of room, and hits nothing.
Thumbs ^IMO, it doesn't hurt performance, but there would be no advantage over a 3" DP til you get into turbos that have larger exh housings exits. Funneling down right at the turbo when the exh wheel is bigger then the pipe dia its going into is not a good idea. Its always about a smooth transition. But it sure does look impressive when you pop the hood and someone comes by and looks at it. Almost adds inches to your pecker................almost. lol
Too bad it is 1/3 as long, barely makes it past her rotten walmart tooth...."Turbos to my mind don't like backpressure of anykind once they have done their work, besides, would you rather tell her you only have a 3" ?"
She knows mine is 3".................................
ACROSS!!![]()
