texasterror
- Aug 7, 2007
Ok thanks for the info. Pulling the engine tomorrow or monday to inspect the bottom end but hopefully the bearings are good. If everything checks out then i'll put her back together with the RJC gasket. I had cometics but it was my dumb arse faualt for not tunning it properly yet stepping on it (I have eric marshalls SD chip). Lesson learned via my wallet. I was just going to go with the factory head gasket because I wanted to put the car back together (And i didnt i'd get a response) but based on your info, i'll order the RJC gasket. My car is built but as good as yours The crank is stock and the heads are stock but polished/cleaned up so i'm sure if i tune it right im in the mid to high 10's.
