turbojimmy
Supporting Member
- May 26, 2001
Okay it's all done. I still have a few loose ends to tie up (still have the questions above) but I drove it around a bit to make sure everything's kosher. Here's pics (ignore the partial white stripe on my front rub strip - I replaced it with a new one while I had the bumper off and haven't removed the rest of the white stripe):
http://www.turbojimmy.com/rjc_mega.html
Even though the pics all look the same, I tried to get the front at a few different angles. You can barely see the pipes with the ground fx in place.
I didn't mess with the grille. It's tight up against the tanks but it's more or less lined up. My sagging filler panels had me fooled before. It might be sticking out *a little* at the bottom but it's hard to tell.
It definitely heats up quicker, but the fans keep it right at 170 like they did before the FMIC install.
Jim
Jim
