And you should NOT be able to suck up through the top, correct?Lee, you should be able to blow up through the bottom, but you should not be able to blow down through the top on the 1162 (unless there's something wrong with it).
Eric
For years I've run a leaky stocker along with an old-school ATR check valve and seen high BLM's at cruise, I think the PCV working OK. I installed a Kirban PCV valve on its own and lost my power brake assist - - massive vac leak. If I run the old stocker alone - - same vac leak. ATR valve on its own - - small vac leak but PCV works, no boost down through the top...
This is indeed confusing
