Rocker arm ratio
monkeyy337
What is the rocker arm ratio on a 231 Buick V6 motor? I bought some roller ones last night and they are 1.55 so was wondering what the stock ones are. Thanks
1.55 is stock. They also make roller rockers in 1.65 which would give you about another .030 valve lift.
I was hoping they were more than stock to get some more lift but I only gave $199.00 plus $15.00 shipping so if nothing else they will be some what easier on the valve train. Thanks for the replys though.
Actually if you caculated the valve lift with a stock rocker you would find
they come in around 1.47-1.48 . So going to a true 1.55 would be an
advantage.
Any down sides for going to the 1.65 performance wise Dan? How much of an improvement do you see on the average.
