Heys Guys....started To Pull The Car Apart Tonight...didnt Get To Far....i Did Not Clean Or Plastiguage Anything Yet...but Once Again...
1....oil Filter Was Empty.....not Right????
2....press Releif Spring On Oil Cooler Adptr Was Loose...does Not Sit Tight....good Or Bad????
3...pan And Pickup Have Metal...aluminum And Copper Bits/dust
4...#1 Rod Bearing Lower Down To Copper In One Spot/upper Most Of The Bearing Is Down To The Copper.....no Gouging
5....#2 Lower Looks Good..nice Actually/top Is Down To The Copper...no Gouging....
What Do You Think So Far?????thanks Guys
