Hi Jim, at the end of the "ESC again thread", after I found my ESC to be working
, you suggested that I try quenching my WOT detenation by adjusting the secondary mixture.
I have finally found the time to check the rods and hanger ! There is an "H" hanger, and "CP" rods presently fitted. I have no reason to suspect that these are not the originals. "Off the cuff " you recommended a "K" hanger, and "CY" or "DA" rods. Either of these rods will give a richer mixture through out the range, except for the first few degrees of opening, and appear to be very good choices. Thanks for this good advice.
All I have to do now is try to obtain them. I think I will fit which ever rods I can get with the existing "H" hanger and take it from there.
Must get one of those A/F thingies, to straighten this out once and for all. Can a carb. really be tuned with one of these things or is it best to" fly be the seat of your pants ", as is customary on such occasions???
