224/224 hydraulic roller, ductile iron custom grind with .335" lobe lift on 110* centerline
Complete double roller timing set
Hydraulic roller lifters - Race version (.000-.002" pre-load)
Matched beehive springs, retainers and locks.
To run this cam I would recommend that you have an aftermarket fuel management system, preferably with wide band sensing. This is a drop-in setup, no machining work necessary. Roller cams idle so smooth!
Cam was in my TSM motor for one season...so there is prolly only 50 passes on this setup. Turned in a dozen 10.1x passes with this stick.
Asking price for whole package - $850 and I'll pay for the shipping.
