- May 25, 2001
Can someone advise us on replacing the roller rocker bearings in T&D type shaft roller rockers?
Has anyone ever been successful as this ? We have acquired the correct bearings. Thought that the removal would be easy (not !)
I fear that the most common answer is send them back to T&D.
Looking for input anyway.
What made you think you needed to replace the bearings, someone may think.
Removed the rocker shaft from one side of the motor, in prepairing to check some valve springs, which are suspect. I let the rockers slide on the shaft, and before I knew it, many needle bearings had fallen though the mounting holes in the shaft ?
TMI I know, but this is what lead to the above question
