Alaskabuick
- Jul 4, 2004
Have been chasing this for awhile on my 87 T. Long Block & Head are Factory stock with exception of 100 lb valve springs.
Basic bolt on build, TE44, 50lb inj, turbo tweak chip, exhaust, THDP, etc.
The miss happens like clock work at 4600-4800 rpm, WOT or NOT. I can stick it in low and give light throttle and run it up to 4600 and it misses, does the same thing at WOT.
Installed new plugs and wires and no change.
Checked coil pack with Caspers coil pack tester.
Checked gap on Crank sensor and seems to be good and not rubbing.
Going to run thru my grounds today just to recheck them.
Hopping someone who has had this issue might be able to shed light on it.
thanks guys,
Dennis
thanks guys,
Dennis
