Rpm's on highway with 3 speed.
So by reading the replies here, I can assume that a TH-400 is very "liveable" on the street...I remember back in the '70's, a lot of muscle cars came out of the factory with huge engines coupled to a three speed automatic transmission and 3.50, 3.73 and even 4.10 rear axle ratios, so I suppose driving the car with 3.42 gears shouldn't be too bad!...:rolleyes: It's true that fuel was not as expensive back then as it is today, but that wasn't my point...My point was that driving the car with a three speed and 3.42's shoulds still be do-able today...
If an overdrive is absolutely needed, then there's always the 4L80E alternative. At one point, I was very tempted to go that route but I was told that they were more touchy to get them to work properly in "performance" applications and also they got to have a separate computer to make them work. It's like if there's not enough demand for 4L80E's at the moment in high performance vehicles, but maybe in a few years from now, we'll see...:rolleyes: ...So I've decided to go with a TH400 and be done with it! :wink:
Claude.
who wants to do that much work swapping units anyway?
I have both transmssions, both Torque converters and both bolt on crossmembers. The driveshaft is the same and the shifter takes 10 seconeds to change out. My brother also has a lift in his 26x26 garage right down the street from me. It's probably an hour or two on a weeknight to get the swap done. Not a big deal to have a part time race trans to be confident at the track and not need a trailer to get home.
Heres a different question.... I have access to a 2.75 upgraded first gear ratio for the T-350. In theory, couldn't you run the numericly higher 1st gear and lower the rear gear to 3.23 or so and get the same results as a 2.52 and 3.50 rear set up but get way better cruising manors on the highway?
I wouldn't even bother with the lower ratio in the 1st gearset. I'd put the 3.23's in it with the 3 speed and forget about the OD.
I'll be honest. I just finished freshening up the 9 inch and put the 3.50 gears into for the LC2 swap. I was thinking they were the best gears for the motor.
Try it and see how you like them with the 3 speed. Lots of T-350 swaps here locally with the 3.42 gear. I don't mind 55-65 mph cruises like that. If I want to run 70 on the interstate I have a truck for that.
Pretty much the answer I was looking for. thanks.
55-65 cruises not being a real chore like a 383 W/ 3.73's is what I want to here.
I have a hybrid with a TH350 and originally started with the 3.50 gears and it was tolerable on the freeway with a 28" tall tire. After posting and getting advice from more knowledgeable members on this board, I changed to a 3.25 rear gear ratio and the car went faster in the quarter mile and is VERY nice to drive around on the street and freeway. I know read you do not want to change ratio but it is food for thought, and I am sure others could chime in and say if your combo would be a good choice for this.
Here is a link to my build and times along the way: http://www.turbobuick.com/forums/hybrids/270436-1963-chevy-ii.html
If I ask the wrong question or make a dumb comment allow it to my age ( old fart ) . About a year ago I swapped the TH 350 in my 34 chevy to a 200-4r . Had a few teething problems ( built it myself ) .Seems to be working well now . Unless it blows up I'll never go back to the 350 . I love the overdrive . With the 3.08 Nova rear and in 4th lockup it's loafing at 70 mph . Out of lockup in 3rd gear it is turning more rpm's than than the th 350 . Maybe it's the D-5 converter ? Just for the heck of it I ran a switched parallel ground to the TCC solenoid to lock it up in 3rd . Feels so good I almost whiz on myself .
