running rich really rich
thanks reggie I will email it to you when I get over to work on it probably thurs. night . I might be able to drive my car soon it's been almost two years . Once again thank you very much for all the help
o.k I checked the crank trigger and adjusted it I also reset the cam sensor because it was off . still no change and the car will not make any power under boost and will "pop" through the intake side .......here's the other thing that has me stumped with a timing lite it shows 11 deg at the factory mark ( i put the tape on to adjust the cam sensor) in the dfi ignition map the value in the cell is 33 . question is how do i adjust the ignition map and is this my darn problem ...... getting frustrated... oh yeah it still runs rich at idle..... thanks guys
could a bad coil pack and module cause perhaps a weak spark causing the car to run rich at idle because even when i make the values in the cells as low as they can go it's still rich. just an idea thst came to me ...thanks
