Hi All,
Well, my little truck is finally roadworthy! I've got all the requisite "legal" stickers in place and all of 20 miles of road time on it. There are several puzzling things ocurring, though:
I can't even come close to matting it, as I'm seeing 18# boost at 1/4 throttle! This is a stock actuator (albeit TIGHT) modified for "fit" on a 45° compressor outlet. I'm *sure* the 'gate hoses are hooked up right...
MAF appears to be pegging around 14# boost, it's hard to tell because you have to feather the throttle to keep from exceeding that value. 238 @ 13#; 253 @ 14#...
I've seen 20# on the boost gauge (again, toeing the pedal) and "0" on the knock gauge. I've suspected the knock circuit is "klabooey", since I've NEVER seen any knock ,and cannot rattle the gauge by hammering on the block or intake. But too, I currently have 10 gals of 93 and 3 gals of Xylene and temps are high 40's...
At a steady road speed of ~40 M/H, my EGT is showing 1140° and these numbers (average of maybe 20 consecutive frames) from my "Lubrant" chip & T-Link:
2225 RPM's (no TCC yet)
42 GPS MAF
4" vacuum (most of the trip, it was around 12", must have been the head wind)
115 LV8
1.28 TPS
124 INT
115 BL
47 xCounts
Please point me in the right direction BEFORE I blow this thing up (again).
42 GPS MAF
115 LV8
1.28 TPS
124 INT
115 BL
47 xCounts
