SignUp Now!Is it me or…I looked at the pictures of your transmission on the first page (where the speedo cable is disconnected) but…there doesn't seem to be any speedo gear in there which would explain why the speedo doesn't work and also it might cause a leak because the little seal in there has nothing to "seal" against!…but again, it might just be the picture…
Claude.![]()
Hi Sally, for whatever it's worth, head gaskets usually don't leak oil,unless something is structurally broken. With a GN, anything is a possibility.
Looking forward to your build!
Cheers!
Claude.![]()
Your missing a plastic ring gear of sorts. It comes in different colors based on tire size and rear end ratio. It slips in that housing and is driven by those splines on the output shaft in the hole.
Nah, Sally, I didn't think you were dumb. Just didn't want to see ya buy a new engine over an oil leak. Of course a built TA motor would be fun too!Ya don't think I'm dumb. I was just thinking where else it could be leaking. Thought I fixed that leak.
