Scanmaster Question??
bobgn
When the car is at wide open throttle the scanmaster reads funny #s like 39.5 or numbers like that. Just started to do that. 2.1 version. GN 61 turbo,50lb injectors,3 inch dp alky {Razors of course} Knew grounds but still wont read right. Any suggestions??? Thanks Canadian Bob
Need a little more info. Is that the left number (O2 mV) or the right number (knock retard)? After a WOT pass what numbers do you get when you press the recall button. Also, it would help to post all your numbers at idle.
Thanks.More information!! AF 05 , L8 33 ,BAE 13.6, INE 128, BL 133, mph o, cle 170,AES 84 R 800, eps .44, IAC 15, CC223 MAL oo. At wide open throttle It reads o42 on the 02 side and ooo on the nock side. Push the right button it says 042 on the left and 000 on the right. Push the other button same time it says 070 and 000. Hope that helps ,hardly any knock at 21 lbs boost with alky on full. Thanks greatly bob
