Scanmaster Question
GrndNatnl
Regal of the Dark Order
On the SM 2.1, when you go for a blast and it goes into record mode, and press the mode button while holding Recall, it tells you MPH at which the lowest 02 and highest KR was recorded. I notice sometimes it says two different numbers for the MPH. Some times it'll say the same MPH on both sides, but other times it says two different numbers. Whats the deal with this? Which number is which? Why does it sometimes have two MPH values? TIA
The values are independant of each other. Just because your lowest O2 value was at 62 mph doesnt mean that the highest KR happened at 62 mph too.
The value on the left is the mph your lowest O2 reading happened at.
The value on the right is the mph your highest KR happened at.
Ah ha! Now it makes sense. Thanks for clearing that up. I couldnt figure out why there were two different readings displayed. :cool:
