Scanmaster quit working
TurboTGuy
Gray Beard Member
TurboBuick.Com Supporter!
Like the title says. It worked a couple days ago but today, I went to drive it to work and it flashed SCN 2.2, then PL 4.8 and then went blank.
Does that every time I start the car.
I'm at a loss, here folks. Any help would be appreciated.
Thank in advance!
Other than checking the connections, there is a setting in the PowerLogger that changes the datastream mode. Thats what I would check first.
Guy, check the connections. Had a few do that. I hard wired them...soldered them...problems solved.
BTW, I did that years ago. :) Still have a little melted spot in the carpet on the trans tunnel where a drop of solder hit. :( I dyed it, so it hardly shows...
Thank you for the suggestion, though.
