Scanmaster #'s, What do you think?
extranjeo
I have some scanmaster numbers I'd like you guys to comment on. These numbers are at idle as I just bought the car late last year. I want to make sure everything looks good and is locked down before I make a WOT run.
O2 765
AF 06
L8 40-44
BAT 13.5
INT 115-133
BL 108
TPS .44
IAC 24
CC 07-250
MAL 0
The temp is 195. If I am leaving any info out let me know I will fill in the blanks. Thanks in advance.
http://turbotweak.com/scanmasterinstructions.pdf
BL at 108 is a tad low, do you have a MAF Translator on there? If so you could bump up the base setting.
IAC is a tad high, as long as your idle is ok, I wouldn't worry about it.
Everything else looks ok, but your temp is on the high side, most of us run 160 degree thermostat's.
Chuck
Chuck
I have a question, with the BL's at 108 doesn't that mean the computer is seeing a rich condition and is pulling fuel to compensate for that condition ? If so can you just lower the fuel pressure until the BL's are within specs (118-128).
