$9600 OBO
Front end;
New control arm bushings
New brake calipers, pads, rotors, brake lines, bearings, ball joints, 36mm hollow GTA sway bar, shocks, fresh alignment.
Rear end;
GN 8.5" 10 bolt w/ posi, GN sway bar, Airshocks, aluminum drums, new wheel cylinders & shoes.
Body;
Honest Charlies SS ChooChoo style frontend, Fiberglass rear roll pan w/ NEW taillights, Class III trailer hitch, Unlimited products 2" fiberglass cowl, Fiberglass side exhaust covers, original arizona car - zero rust, minimal bondo used before paint, Line-X spray in liner (I went through 3 angle grinders and a bunch of wire wheels stripping the bed before spraying selfetching primer before the sprayed in liner was applied!)
Int;
40/60 split bench w/ all new foam and material & fold down armrest w/ cupholders, sound insulation installed before new carpet, Gbody parts upper door panels, '84 GN lower door panels, new ABS headliner, '84 GN dash w/ Autometer gauges, '84 Grand Prix steering column (wipers on column). My original '87 GN spare tire is in smugglers box w/ Jack.
Just replaced steering box, has new F-body radiator, new waterpump. Newer alternator, powersteering pump, a/c compressor.
