Not sure if this is the correct forum, but...
I've always wanted to record boost on my DirectScan system. I am thinking that if I hooked-up a GM MAP sensor to an un-used A/D pin on the stock ECM, then maybe some chip code could be written to convert the signal from the sensor into at least a hex value in one of the ECM's registers.
Anybody ever do this before? Is there an un-used pin on the stock ECM that could be used for this purpose?
Thanks,
Thanks,
