84buickregal
- Jul 16, 2008
any one interested on makeing a kit for these?
SignUp Now!Been thinking on this more and more recently. Again mainly because I need custom headers and a new intake won't hurt anything for my '64 Riviera. Some questions to answer before I go too much farther down this line of thought.
1. Can you get a cam with a Stage II lobe order but a conventional snout?
2. How do Champion CNC irons compare to heads on this list: FirebirdV6.com/CamaroV6.com Message Board - View Single Post - The Heads and Cam Bible.
3. How much flow impact do the head mounted injectors on the L67 heads have and any issues with them running lean at higher rpm's?
Thanks,
Thanks,
This is a bit convoluted. I'm thinking of swapping the heads off of a Series II/III onto my 1984 4.1L block. The cam lobes on the Series II/III are in the same order as the Stage II classic V6 so I'd need a cam that used the Stage II cam lobe order but with a conventional timing chain because switching to the oddfire nose would be slightly problimatic but not unrecoverable.1. I have no idea what you are asking. If you are referring to Stage II GN cams, I cannot compare anything series II with the exception of displacement.
2. From what I have been told (which isnt gospel) stock series II heads flow better than most ported GN heads. I have only heard of the Intense heads on that list, and they are pretty solid heads in the 3800 community.
3. If you are using the fbody upper/lower intake manifold setup for a series II in a RWD setup, you will have L36 heads, not L67 heads. L36 heads do not have the injector bosses in the heads, as they were located in the LIM.
Not sure this helped you much. I havent kept up with the 3800 for a couple years, so my knowledge is a little rusty.
Car will be back out for some #s this year for sure. Ill finally have some extra time, and money if im luck![]()
I don't care what anybody says. I love it when people can think outside the box and still keep it Buick powered!!!!!!!!!
Subscribed!
Hopefully this will help my 88 Firebird project get some wings! Yippee!
