Thanks Ryan--appreciate your educating me (for sure) and the rest of the crowd (likely some).
Understand we may be a while away from a kit, but my GN is in the barn in AR, and I won't start swapping out engine stuff for at least a year.  Also, I have a nice pick and pull yard here in Albuquerque, so I can get stuff relatively cheap.  So here is the list of what I think I should start procuring in the yard, based on all the posts above.  intent is to begin getting the engine and tranny ready, hoping for wiring, accessory brackets and exhaust to all come together in a kit later.  Some of the parts listed in the earlier posts were for a specific year, but I suspect thats just the year he found and there are probably a range of years possible.  Plz advise if this is the right list to get from the yard, and my interpretation of the above posts is correct.
Engine Block:  Appears any series II/III from 1995-up will work, but the 96-03 L67 will have the strongest internals, and will be a higher mileage block which is a good basis to start from.  L-32 supercharged Series III will also work.
The 3800 Series 2 engine was introduced in 1995 in N/A form (L36) ONLY.  1996 was the first year the 3800 Series 2 Supercharged (L67) engine was available.  The 3800 Series 3 n/a (L26) and SC (L32) was rolled out in 2004.  The 3800 Series 2 engines were still used by GM thru the 2005 model year.
			Heads:  Series II or III NA (L26 or L36) will both work, with L36 having the higher flow rates.  Neither require plugging injector holes.  However, Supercharged L32 Series III are the best flowing, but require plugging injector holes.
The castings for these heads are basically identical.  So if you are going to port the heads and do valve work, it really doesn't matter what year or engine they came off of, IMHO.  If you want to use the bigger valves out of the Series 3 heads in a set of Series 2's, I'm sure all that is required is some seat work.  But if you are going to go to the trouble of doing this, why not put even bigger valves in them???  I believe Dave at TripleEdgePerformance has experience with this (LS1 valves???).
			Intake/Plenum/throttlebody/PCM/Wiring Harness/oil pan:  Get 96-98 F-body units.  Not sure if only 98 PCMs work, but that's recommended above.
The 3800 Series 2 (L36) n/a engine was available in the 1995 - 2002 Camaro/Firebird.  There is NO tuning software available for 1995 PCMs, period.  There is very limited support available for 1996 PCMs but 1997-2002 seem to be the most widely supported.  1998 PCMs are "better" than earlier computers because of their availablility and hardware configuration.  Starting in 1999 model year, ALL F-body 3800s came with FLY-BY-WIRE throttle control (has different intake and throttle body vs. earlier engines).  I recommend steering clear of this setup for these swaps.  I do not know if the 99-up upper intake plenum can accept a cable-op throttle body without adapter plate -- never looked at one that closely.
			Mounts:  Get Mid-80s V-8 Cutlass frame & motor mounts.  Posts also suggest a Cutlass Crossmember, and early to mid 80s 700R4 tailhousing to add to 4L60E for mounting.
Tranny:  4L60E built.  Posts aren't clear to me, but believe you must get an F-body trans from behind a 3800, and get it built to withstand the power levels expected.
I would verify this with Dave at TEP.
			IF the above is correct, seems like the easiest approach would be to get a complete engine/tranny combo from a 98 Camaro.  Posts above suggest new pistons, the question is whether you need the crank/rods from the supercharged.
From what my research has turned up, I have been able to determine the following based on the information I have been able to find...
-All 3800 Series 2 and 3 blocks are the SAME.
-All 3800 Series 2 and 3 heads are the same casting; just some minor differences concerning machining for n/a vs. SC apps; and Series 3 vs. Series 2 (mainly valve size as far as I can tell)
-All 3800 Series 2 and 3 cranks are the same.  But there might be differences that come in to play in counter balance weight amounts being different between SC and N/A versions to count for the difference in mass of SC vs. N/A rods, pins, pistons, etc.
-These engines are balanced externally meaning the harmonic balancer and flywheel have counter balance weights in them.  THESE ARE DIFFERENT between N/A and SC engines.  The counter balance shaft used in the block above the camshafts are also different between SC and N/A engines.
-As mentioned above, connecting rods, pistons, and pins are different between N/A and SC versions of these engines.  The SC versions are much beefier (have verified this myself with side-to-side comparisons).
-Oil pumps are run directly off the crank and are mounted in the front cover.  All are the same Series 2 and 3, n/a and SC.  Oil filter mounting housings are removable and there are several different ones available depending on the year/make/model of car the engine was used in.  Many are still available new from GM.
			At my pick a part, the prices are 1) complete engine w/accessories $260 2) Engine block, $95 3) engine w/heads/intake $175, 4) Heads $80 5) Intake upper/lower $50 6) Tranny $120 7) Throttle Body $25, 8) wiring harness $28 9)Oil Pan $20.
If I want to put an engine together at the yard, I could mix and match and get complete engine/tranny/accessories/wiring harness for a little over $400.  If I buy the complete F-body setup, and get the L67 block for the internals, its another $95.  Tranny Crossmbr ($13) Tailhousing ($15) an frame mounts ($8) get us ~$530 for all the parts.  If I don't need the F-body accessories, can shave off $85 bucks....
So what do you think?  Is this the right way to get all the parts?  What would any of you do differently?
I'm assuming stock turbo/IC all stay the same...
Thx for any clarifications/corrections/inputs you may have.
If this were a swap I was doing, I would first obtain a SC shortblock (L67 or L32).  I would then obtain N/A (L36 or L26) heads.  The F-body cars were available with cast aluminum valve covers.  All other cars came with composite (combination of plastic/fiberglass) valve covers.  If you get a set of SC heads, you will be forced to work with factory composite valve covers because the sealing surface that would allow you to run the n/a valve covers has been partially machined away for the injector holes.  There are aftermarket machined aluminum valve covers available for the SC heads, but they are pricey.
Next I would obtain an intake and throttle body from a 1995-98 F-body.  You can use an Assy drive (alt, A/C, p/s pump) from any F-body -- if that is what you want to work with.  The only problem with this setup is it wants you to put the A/C compressor low on the engine where it will interfere with the crossmember.  I have an idea of mounting the factory GN pancake style A/C compressor on the odd (left) cylinder head and running it off the front belt pulley grooves on the SC balancer (all other assy's use the inboard belt pulley grooves).
I would probably make my own wiring harness, but would try to start with one from a 1998 F-body Auto car.  I would use a 1998 PCM and a built 4L60-E trans.  Would also custom build headers and crossover pipe similar to what Dave at TEP did in his GN swap.  Obviously mine would have to be different to accommodate for the A/C compressor / lines.
But that's just what I would do.
-ryan
