SignUp Now!Suggestions? Short of full rebuild lol.I see that impeller all over those pistons
Sent from my SM-N930T using Tapatalk
So nothing to try and clean the pistons then? Works for me.I'd run it..
I bought a kit from a member here a few years ago which has the 33c, walbro 340, hotwire, 42.5 injectors , adjustable fuel pressure regulator and corresponding tt chip Less than 1k miles on the parts. Also added caspers fuel injector harness, power master alternator, caspers Alt harness, egr block off, and new timing cover with high flow oil pump. Have a melling 20-is6 and 20-is2 and will put in whichever fits best.Not sure if you know . . You should pm Bison for a turbo. He will do it right.
Absolutely semi stock. It's a peg leg right now anyways. But I have a gn posi that I will be swapping in. I would like to but not sure if I have the time to do any porting. Basically just port match to the intake gasket I assume? Trying to be ready for Cecil county and I am leaving for a week long cruise today. Bad timing. Lol.Looks good.
Did you find the nut or debris in the intake?
Also . . . . I am going to ass-u-me you are just buidling a semi stockish car? In that case, if you haven't put the intake on yet, I would port #4 ONLY. Leave the rest stock.
93 premium. I'll stock up on some octane boost for track nights, or even buy some race gas at the track. Just wanna have fun, wrench a little bit and have a reliable daily.Port matching will be better than nothing. Lol
What fuel will you be using?
Since you will be bored at times on the cruise, try to search the thread "interesting numbers". Have fun and good luck.
How'd it do that?
Sent from my LG-H740 using Tapatalk
