SES
T Carter
Hi fellas,,, I have a issue with the SES light on my gn. This car came with a cyberdyne digital dash, i had noticed that the ses light never came on or flashed when turning the key on, of course i thought that the bulb was shot. I took the dash apart and there was no bulb in the plastic pod, nor was the pod locked into place in the dash socket. I put it back into place and placed bulb in the socket turned key to on position and presto, so i thought, the light never shuts off when the ignition is on. What wire feeds the SES light
hi, rick.. any ideas on what causes the SES light to stay lit? I am wondering if the installing of the cyberdyne digital dash caused this issue. I have a scanmaster and no mal codes .
The SES will stay on until the engine is running. At key-on, engine-off the SES should: turn on briefly, blink off, then turn on solid. Can repeat the test after at least 10 seconds of key-off.
The ECM provides a ground to turn on the SES light. If the quad-driver in the ECM is toast that can cause the SES to always be on.
RemoveBeforeFlight
I was wondering. If the bulb stays on, when I go to Install the new chip will the ses still flash off and on like the instructions speak of ?
I believe that all chips should cause the SES to blink off. Another test you can do is to remove the PROM and do a key-on, engine-off. If the ECM is running OK the SES will be rapidly flickering. This is the ECM doing a checksum of the chip contents which of course will fail.
RemoveBeforeFlight
I don't mean to sound stupid, is the prom another type of chip in the ecm?
The prom is the "chip".
Ok. Gotcha ... What is a modded ecm
Driver updates for larger injectors.
Not any more. The new style high impedance injectors work with the prom. You just have one of the vendors burn a chip for your combo including injectors.
I gotcha. I have new tt combo kit
