Setting Timing
The injectors are original I'm thinking going through them having them cleaned and flow tested can't be a bad thing.
The frustrating part is she was totally knock free and ran a 14.33 on stock tires and everything else with zero knock at 12-13lbs on stock chip.
Joel
Did the knock start after or before exhaust. Can be exhaust banging off control arms or other areas.
We'll check out as many possible causes of the knock when you come by.
Before. Thought it might have been the gas. Drained tank and fresh 93 in it now.
