robzombie
- Oct 10, 2012
Why is it that with a 3" maf and extender extreme chip that all the 3" settings say not for E E chip???
Which setting is recommended, as I'm chasing a slight rough idle and intermittent stall on throttle tip out at cruise.
Using EE param #9 enabling DFCO works, but I usually forget to put it into drive instead of leaving it in od [I drive over 55 mph 90% of the time] before it stumbles and them stalls.
I run all dips up and right now 2,8,0,0 on the knobs.
This is the maf instruction page off the web site.
MAF BASE MAF WOT
0 3.5 LT1/LS1 MAF sensor No Change
1 3.5 LT1/LS1 MAF sensor (richer at idle) 2% Rich
2 3.5 LT1/LS1 MAF sensor (leaner at idle) 4% Rich
3 3 Caprice/Impala MAF sensor
(not for Extender Extreme)
6% Rich
4 3 Caprice/Impala MAF sensor (richer at idle)
8% Rich
5 3 Caprice/Impala MAF sensor (leaner at idle)
10% Rich
6 85mm Plastic MAF 12% Rich
7 85mm Plastic MAF (richer at idle) 14% Rich
8 85mm Plastic MAF (leaner at idle) not used
9 4 MAF with integral sensor 14% Lean
A 4 MAF with integral sensor (richer at idle) 12% Lean
B 4 MAF with integral sensor (leaner at idle) 10% Lean
C Not used 8% Lean
D Not used 6% Lean
E Not used 4% Lean
F Not used 2% Lean
MAF BASE MAF WOT
6% Rich
8% Rich
10% Rich
C Not used 8% Lean
D Not used 6% Lean
E Not used 4% Lean
F Not used 2% Lean
