Jul 28, 2004 #1 J jetmech Member Joined May 25, 2001 Messages 1,086 what is the pattern on this trans. i bought a b&m pro stick and was wondering if it set up for standard pattern or reverse. Is it p r n 1 2 3 OR 1 2 3 n r p
Jul 28, 2004 #2 O odell4o8 Member Joined Jun 9, 2001 Messages 867 pattern, the one in my car is p r n 1 2 3 manual valve body with trans, brake.
Jul 28, 2004 #3 J jetmech Member Joined May 25, 2001 Messages 1,086 thanks, just the info i need. I think i need the adapter plate for the shifter to make it reverse pattern
Jul 31, 2004 #4 J jetmech Member Joined May 25, 2001 Messages 1,086 One more ? When using a manual valve body trans, do you need to shift it manually all the time in both directions or just when racing
Jul 31, 2004 #5 O odell4o8 Member Joined Jun 9, 2001 Messages 867 SHIFT PATTERN manual shift all the time, it dont matter if you are going slow or fast, my trans, free wheels in 2nd gear, like neutral, good luck oc,
Jul 31, 2004 #6 J jetmech Member Joined May 25, 2001 Messages 1,086 thanks OC, anything special i should tell my tranny guy to put in the th400 when i have him build it. Its going to be a 10 sec trans. with a t-brake. thanks Rich
