Another wiped out cam story:
I wiped a lobe on my stock block. I am in the process of pulling the engine to replace the cam and have a couple of questions. At what point will I see the benefit of porting the heads? I will be replacing the cam with a flat tappet, stock or slightly bigger (206/206 or 208/208). Most likely i will add a PTC converter, and upgraded intercooler (maybe just a Dutt neck) at the same time. I want to have a little room for a little bit larger turbo if i find the scratch!
Will i see that much of a diiff porting the heads? Also does it seem cost effective? I see a lot of guys on this forum that like to spend other people's money, but i am trying to do this on a budget and get the most bang for my buck. My goal is to have an 11 second ride with 95% of the time seeing street duty. No track times because the cam gave up, but i was running 24psi when this tragedy happened. I appreciate all your guys input.
