Should I go with DR's or Slicks For the track?
baller760
I have a pretty much stock GN. The only mods I have and will be adding soon are an adjustable wastegate, adjustable FPR, 3'' ATR downpipe with 3'' cat and Hooker exhaust, a new turbotweak chip, 42.5 lb/hr injectors, some QA1 adjustable shocks up front, and Edelbrock IAS's in the rear, with some new springs and air bags. I am also ordering some 15X8 Centerline Telstars for the rear and was wondering if I should go with MT DR's or MT Drag Slicks? These tires will be for track use only by the way. Thank you.
slicks will always hook better than DR's........changing tires at the track sucks, so depends on how serious you are about going fast
Yea, and when you goto the track........Forget the cat... I don't care how high flow it is......
