Occasionally when parking or sitting in traffic (idling in drive), after the trans is hot, I get a shudder. The car doesn’t stall or bog down, it just bucks. It doesn’t matter what position the gear selector is in. The trans is non-lockup.
Did I set clearances too tight on a clutch pack? Too loose? I had a pressure gauge on it for a while after installing the trans. While the pressures at Max TV were lower than desired, the trans performs great. The fluid looks and smells fine.
