Some of this thread was lost but I'll update where I am on sleeving the block.
I purchased an L.A. sleeve with a 4.000" O.D. and 3.780 I.D. with a flange at the top. I bored the #3 bore to .020" under the sleeve O.D. and put the step in the top of the bore for the sleeve flange. The step is .010" less than the height of the flange so it will be above the original deck. The diameter at the flange will have no interference fit.
After putting a torque plate on I then honed the bore to 3.998" to have a .002" interference fit with the O.D. of the sleeve.
Here is the bore ready for the sleeve.
I then packed the sleeve in dry ice for a few hours to shrink it and heated the block to about 150 degrees in an oven to expand the bore. I removed the block from the oven and put a ring of Loctite green around the bore approximately 2" down from the top. I then, using gloves, took the sleeve out of the dry ice and quickly pushed it into the bore until the flange was seated. The block was then decked.
After the deck machining it was back to the hone to finish the sleeve bore to size and finish for the #3 piston. With all the machining complete the block was cleaned in a power wash. Here is the finished sleeved bore ready for assembly.
After assembling the short block I would like to temporarily finish the engine and run it on the dyno to seat the rings and verify everything is okay. I will be looking for a 4 bbl intake and an HEI single wire distributor to be able to run it without all the normal ignition and fuel items.
Mike
