JDSfastGN
- Jun 16, 2001
Ok so I’ve been driving the Buick recently during these hot summer months. I’m tired of the car not cooling well.
It has a Lincoln mark8 fan installed flush, nice aluminum radiator from red C5, all the baffles, an air dam that goes across the entire underside below the radiator, 160 thermostat, high flow water pump etc….
On a warm 85* night the car runs 167-170 with no AC just cruising (180-185 with it) but after a good blast it goes to 185 and takes a while to drop below 180. Back to back spirited runs bring up 190 195 pretty quick. I won’t even talk about with the AC on during the day when it’s 95+. Maybe I’m asking too much.? I have a FMIC that has a very thick 4”+ core with end tanks that block airflow and that I think is probably my main issue. I would like to run a SLIC again. My only problem is ground clearance. My car is very very low. I had a BGC 23 row on there when I initially did the suspension and very soon after snagged the intercooler on a 3” “step” getting into their garage, slamming it into my crank pulley and thus destroying the intercooler.
So what is my compromise? New or used is fine. Who makes a good SLIC unit that has good ground clearance? The car is a 10.70@128 car as it is and I would like to keep it that way. I guess since I run alky I am more worried about pressure drop and how well it flows assuming the SLIC will not drop the temp quite as much. I have aspirations to road race it for fun, but I know as it sits unless it was a <50* day, I would likely run way too hot and end up hurting something.
Does anybody have length measurements of their SLIC? My dads T has a thunderfab unit that would hang too low, but I’m wondering how plausible it would be to possibly cut off some rows and re-weld it? Any advice is appreciated. Thanks guys
CLIFFS: Who makes or made a SLIC with good ground clearance that will not be detrimental to my 10.70 93/alky car?
