Sloppy Steering
TURBO2
I have a 1986 GN and my steering is very sloppy. If the road has any contours to it, the car will follow it. I tried a suggestion to tighten up the steering box and it made no difference so I ordered a new box. With the new steering box, different rims and tires, and a front end alignment it still has made no change. The mechanic that did the work said that the rag bushing looked like new and the suspension pieces were all good. What could be causing this?
I have the same issue on my 87.
I had to change upper and lower ball joint to tall, shocks, arms, and add a. Bumpsteer kit
Oh and adding a thicker rear sway bar helped alot
If you still have the rag joint in the steering shaft that causes a lot of slop
. That’s why a lot of ppl replace it with a Jeep steering shaft to eliminate that rag joint .
The rag joint could look alright but I’m sure that’s what’s causing your play in the wheel .
Do you know what part number to use to get the right Jeep shaft?
I don’t know the part number I pulled mine at a junk yard . I believe it came out of a 90s Jeep Grand Cherokee. If u do a search on here I’m sure you will find a part number.
Have you made any progress on your steering problems? I'm chasing steering slop as well, although I don't have any issue with mine following the road contours.
Stock wheels?
After years of being sidelined by life, I now have everything replaced in the front end. Steering linkage, upper and lower control arms, ball joints, sway bar bushings, tie rod ends, shocks, springs, steering box, upgraded steering shaft and bearing, rims, tires, front end alignment, and it still has play in the steering. The steering wheel has no movement up, down, left, or right and everything is new, and the steering box is adjusted to have no play, but the car still steers like shit.
We had similar issues. We replaced EVERYTHING you could replace and it helped some but not enough..we replaced steering box, switched columns, the bushings and bought steering shaft replacement from G Body. We tried the Jeep shaft first in fact and it did not help it any. The smoking gun in the end was the bolt/nut that squeezes the top of the shaft was not tightened sufficiently and once we really put the torque to this it helped tremendously. The rag joint may have had some play in the GM part over time but when we bought the new steering shaft and really tightened it down the play was gone.
Did you look at the steering system. With the car parked and someone shifting the wheel left and right a few degrees. Any play should be easy to see or feel.
The rag joint is only a problem if it's broken. A fresh one is as tight as any universal joint. I also do not like to omit the slip joint with these aftermarket shafts. When a body sitting on rubber bushings and the front left frame horn are wiggling around. Nothing in the steering box or column is ready to deal with length change.
