smc kit
1986TR
"EVIL RGL"
has any one had problems with the smc pump? thier new pump iam asking about:biggrin:
Are you looking to purchase a new alky kit or just inquiring about the one you currently have?
I thought i had a problem with it.The pump quit spraying. The pump ran but there was no spray.I took it apart and found the MM oil i had put in the alcohol had jelled with moisture in the alcohol pluging the screen to the pump.Cleaned it out and no longer use MM oil in the alcohol.The new smc pump doesn't need lube.Problem free now.
Yeah, only the old school SMC pumps needed the lube, the new ones you just dump your alky in there and get after it :tongue:
THE REASON FOR THE QUESTION IS THAT MY BUDDY SAYS HIS PUMP HAS GONE OUT TWICE RECENTLY:confused: AND HE HAS THE LATEST KIT THE PROGRESIVE KIT:eek: AND YES IAM PLAN ON BUYING ONE:biggrin:
Wow first time I heard this with the new pump what did Steve say?
Then why are you buying a kit that has a pump that has gone out twice recently:confused:? Buy one of Razors kits and get customer support to go with it.
why jump to conclusions?i just wanted to see if anyone had problems with their pump.....this guy might be causing his own problems(wrong alky/mix not installed properly etc):biggrin:
For the same reason the thread below this one with SMC in the kit is littered with buy Alkycontrol posts.
I have got the smc jit on my car and it works perfectly. I mounted my pump by the fan shroud instead on the ac accumalator. Because I have freind and his pump keep going out, due to the heat of the downpipe. Since he moved it, its fine. If your kit is the newest, it clearly says non-lubed alky.
Any pic's of the install??
Here are a few pics. I have got the pump neatly to the fan shroud. If need more pics or info let me know. If cant tell anything by these pics, give me email and I will take some full pics and send them to you. Mike
